if I write text into the editor very fast, but if I do so I have a delay and CPU usage raises up to 100%. If I stop writing, for a few seconds the typed letters go on appearing on the screen.
In the normal Memos in the app text could be typed in very fast without delay.
What could it be? Anybody who had this problem too?
Torsten
Slow keyboard inut and high CPU-Usage
Do you use TRichViewEdit or ScaleRichView?
Do you use the newest version?
Do you use live spelling check?
Did you change any properties?
What are your computer characteristics?
Last edited by Sergey Tkachenko on Fri Apr 15, 2011 11:52 am, edited 1 time in total.
