Problem with arrow
Ceprotec
Problem with arrow
Post by Ceprotec »
Hello Sergey.
I'm having a problem to move the keyboard arrow up. Down, left and right works ok, but when I use the up arrow the cursor leaves the srichviewedit and goes to other components. How do I fix this?
How to reproduce this problem?
Ceprotec
Post by Ceprotec »
What happens when I press the up key / ^ \ the cursor leaves the SrichViewEdit and goes to another component of the window, eg a TEdit. This only happens on the up arrow, the others are right.
I created a new project, placed TEdit and TSRichViewEdit on the form.
Ran it. Clicked TSRichViewEdit. Pressed "up". The caret is still in TSRichViewEdit.
Ceprotec
Post by Ceprotec »
Ok, thanks. But you know what might be causing this? Well I checked with one of DEMOS and everything is equal. I do not know what may have caused this ... :(
Ceprotec
Post by Ceprotec »
Sorry Sergey, I discovered that the problem is the project I'm working and do not have to do with srichviewedit. even more. :?
