RvHtmlImporter v0.0039 - 0.0048
RvHtmlImporter 0.0039
http://www.trichview.com/resources/html ... import.zip
impr compatibility with TRichView 13: reading HTML in TRichViews where lengths are measured in twips
fixes
http://www.trichview.com/forums/viewtopic.php?t=3577
Last edited by Sergey Tkachenko on Tue Oct 29, 2013 9:40 am, edited 4 times in total.
RvHtmlImporter 0.0040
RvHtmlImporter is updated for compatibility with Delphi XE2 and TRichView 13.4.
The main modifications are related to a changed type of item tags (they were changed from integers/pchars to strings).
Tags are used for storing hyperlink targets.
RvHtmlImporter 0.0042
RvHtmlImporter v0.0042
Requires TRichView 14+
impr: the importer assigns 'Hyperlink' style-template to hyperlinks, if this style-template exists, and RichView.UseStyleTemplates=True
impr: this version of the importer supports all possible named entities (e.g. α ♠) when compiled in Delphi 2009+.
RvHtmlImporter v0.0046
The same location.
RvHtmlImporter is updated for compatibility with TRichView 14.5
Packages for RAD Studio XE4 are added.
RvHtmlImporter v0.0047
Packages for RAD Studio XE5 are added.
RvHtmlImporter v0.0048
The same location
fix: font sizes for sub/superscripts were halved
fix: supporting 'transparent' value for table background color CSS
fix: supporting cell background color CSS
(note: CSS support in RvHtmlImporter is very limited)
