Unicode RichViewEdit ScaleRichViewEdit
TThiel
Post by TThiel »
In RichViewEdit Unicode work fine. but in ScaleRichViewEdit not.
I set
RichViewEdit1.RTFReadProperties.UnicodeMode = rvruOnlyUnicode.
and use the TRVStyle1 from RichViewEdit with
Unicode property = True for all RVStyle1.TextStyles
If I use this a strange behaviour occurs: A correct letter is displayed at the begining of the text and then an undifined letter was written to the right of it and cursor returns to the start of the text.
Do you change Unicode property of Styles when the document is already displayed? It is wrong, you need to do it when the editor is completely clear (after calling SRichViewEdit.Clear).
Or use the procedure ConvertRVToUnicode from http://www.trichview.com/forums/viewtop ... t=70#11569 (from the second message in this topic).
ConvertRVToUnicode(SRichViewEdit1.RichViewEdit.RVData);
ConvertRVToUnicode(SRichViewEdit1.RVHeader.RVData);
ConvertRVToUnicode(SRichViewEdit1.RVFooter.RVData);
TThiel
Post by TThiel »
I found the problem.
If I make a clear before loading from stream it works fine:
old not working:
SRichViewEdit1.RichViewEdit.InsertRTFFromStreamEd(TempStr);
new working fine:
SRichViewEdit1.RichViewEdit.Clear;
Thanks Sergey you gave me the needed hint.
Hmm..
InsertRTFFromStreamEdi is an editing operation (undoable by the user).
It requires a formatted document, so the correct code is
SRichViewEdit1.Clear;
SRichViewEdit1.Format;
Or, if you do not need an editing operation:
SRichViewEdit1.RichViewEdit.LoadRTFFromStream(TempStr);
Last edited by Sergey Tkachenko on Sat Mar 19, 2011 4:05 pm, edited 1 time in total.
TThiel
Post by TThiel »
OK, this works, too.
I corrected the code: changed RichViewEdit.Format to Format.
(TSRichViewEdit.Clear/Format clears/formats not only the main document, but also a header and a footer)
