doubt with editor
Ceprotec
doubt with editor
Post by Ceprotec »
Hello Sergey! Everything good?
I wonder if there is a tool that can play in several SRichViewEdit sequentially.
Example:
suppose a 'select ...' return 10 records, as these records become the srichview text, one below the other .. make a list like a table??
May be you can create a table (TRVTableItemInfo), add contents of records to it cells, then insert this table in TSRichViewEdit?
Ceprotec
Post by Ceprotec »
Maybe, but not necessarily inside a table. I need to make records that are the result of a 'SELECT ..', but does not know how many records are Listed in Srichview. As if to create a list of names:
-John, male
-Mary, female
-Jorge, male
-Joan, female
Example: 'select * from customers ", those records would come from the database and would be inserted into Srichviewedit.
There is this possibility?
When you executed this sql query, where the results are stored?
If, after executing, you can know the number of results, you can create a table (TRVTableItemInfo) with this number of rows.
If you get your results one by one, you can add rows to the end using table.InsertRow method.
Ceprotec
Post by Ceprotec »
How do I get the cursor inside the possicionar srichwview next to a word, type stand beside the word "name", to use insert statements and put those records that the bank in return text without using table??
Sorry, I do not understand. Can you explain in other words?
May be with examples showing what you want to implement.
Ceprotec
Post by Ceprotec »
How do I direct the cursor after a string in the text?
example, within a text, find the word "name" and find the cusor beside her?
SearchText searches and selects the found text.
Ceprotec
Post by Ceprotec »
what are the parameters? what is a SrchOptions?
