Protect content of SRichViewEdit
charles.lambert
Post by charles.lambert »
I'm creating a little application to create some reports. I've added a SRichView at design time and I allow the user to add some components like radiobuttons, checkbox, ... into the SRichView. This way he can create some reports.
What I want to do is to save the report he created in the RVF format and then set every component and text to read-only, so that no one can change the content of the report...
I'm able to protect a paragraph from modification using this:
 ARichEdit.Style.TextStyles.Items[ARichEdit.CurTextStyleNo].Protection := [rvprModifyProtect];
But I just can find a way to do the same thing with a radiobutton or some others components....
Hope you can help me
- Charles
Currently, the only way to make controls read-only is to make them disabled.
