lines of page and pagebreak
bazzany
Post by bazzany »
i have some questions
- how can i get the number of lines on a page
- how can i know if my data/items can fit to a page, so if i know then i can format them and put into next page
thanks
You cannot know if document can fit to page or not without formatting it.
Do you ask about TSRichViewEdit or TRichViewEdit+TRVPrint?
bazzany
Post by bazzany »
TSRichViewEdit+TSRVPrint
actually i have to construct a full document with certain layout for print and or export to other document from multiple TSRichViews. I have to put a paragraph into next page if it's not fit in current page.
If you simply need page breaks between paragraphs rather than inside them, use rvpaoKeepLinesTogether option for paragraphs.
