Table in table again
delphilord
Post by delphilord »
i have a table in document.it is first item.(itemno=0).
let's name it table_A.
in cell [2,2] of this table I have another table.Table_B.it is second item in this cell.
I want to add rows to this table_B that is in one of Table_A cells.
how to get cell as richview control? any other possible solution?
what is the best way to do this?
Is the table in TRichViewEdit or in TRichView?
If in TRichViewEdit, should it be an editing operation (undoable by the user)
delphilord
trichview.
No user action needed.Document build by code,and user can not edit it.
delphilord
I think this way
1-Getting parent (outer) table item - It is easy
2-moving in to cell[2,2] HOW?
3-geting table again
4-add row
is it possible to get inplace editor for desired cell and get table in it?
delphilord
Sorry I don't want to spam. but I can use trichview or read only trichviewedit.
any solution with this two possiblity
delphilord
I found a working but very unclear solution.Also I am not it is safe,Sure they must be clear and clever code to do this
 rve.SetSelectionBounds(0,0,0,1);
     if not Rve.CanChange or
     not rve.GetCurrentItemEx(TRVTableItemInfo, rve2, item)  then Exit;
     tableX := TRVTableItemInfo(item);
    // ItemNo := rve.GetItemNo(tablex);
    // rve2.BeginItemModify(ItemNo, Data);
    c:=2;
    r:=2;
    RVData := tablex.Cells[r,c]; // or RichViewEdit1.RVData
    RVData := TCustomRVFormattedData(RVData).Edit;
    if tablex.getEditedCell(r,c)=nil then  exit;
    Rve3:= tablex.getEditedCell(r,c);
    rve3.SetSelectionBounds(GlobalTableno,0,GlobalTableno,1);
    if not Rve3.CanChange or
    not rve3.GetCurrentItemEx(TRVTableItemInfo, rve4, item)  then Exit;
    tablex := TRVTableItemInfo(item);
    ItemNo := rve4.GetItemNo(tablex);
    RVData := tablex.Cells[tablex.RowCount -2,0]; // or RichViewEdit1.RVData
    rve4.BeginItemModify(ItemNo, Data);
     tablex.InsertRowsBelow(1);
A solution using cell editing is for non-readonly TRichViewEdit.
As for TRichView,
Table_A := RichView1.GetItem(0) as TRVTableItemInfo;
Table_B := Table_A.Cells[2,2].GetRVData.GetItem(1) as TRVTableItemInfo;
Table_B.InsertRows(...);
RichView1.Format;
