Problem Load RTF File with TSRichViewEdit
davidc
Post by davidc »
I try to open a RTF File with TSRichViewEdit and don't open righ.
Enviroment
TSRichViewEdit v3.6.1
IDE Delphi2010
Code for open file
//config SrveEditor =>TSRichViewEdit
  SrveEditor.Clear;
  SrveEditor.RichViewEdit.DeleteUnusedStyles(true,true,true);
  SrveEditor.RTFReadProperties.ReadDocParameters:=true;
  SrveEditor.RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
  SrveEditor.RTFReadProperties.ParaStyleMode := rvrsAddIfNeeded;
  SrveEditor.RichViewEdit.LoadRTF(OpenDialog1.FileName);
  SrveEditor.Format
- RTF File Loaded don't show breakpage right way. I open this RTF File with MS Word And looks correct.
- RTF File was build by FastReport Components (TfrxReport + TfrxRTFExport).
- I try Runtime And Desing Time. Don't work
Any Idea?
I am not sure that I understand what's the problem with this RTF file.
But if it contains floating objects, they will not be imported, because TRichView and ScaleRichView do not support floating objects.
