Unicode problem..
viperpix
Unicode problem..
Post by viperpix »
i've been sent my problem about unicode caret pos mess as an email to you, and im still waiting for ur answer, i hope that could be solved easily!
thanks.
Probably you did not receive my answer.
Your email contained only a picture. But unfortunately I do not understand Arabic, so I need
- source document
- very detailed instructions (which characters to press) what I need to do to reproduce this problem.
viperpix
Post by viperpix »
no i didnt received anything!
this is not a real arabic text, its just full of random characters! i've edited manythings there till i've found this problem again (cuz there is no constant procedure to achieve that!) but i'll try to find out how!
and one more thing! :D what's wrong with my rve cuz while i have pictures inside the text and i try to change the position of any of pictures by mouse, picture is lost and seems to be deleted!
viperpix
Post by viperpix »
.. and i should mention that it wasn't like this before, and i hope you know which kind of changing in RVE's properties would make it like this
viperpix
Post by viperpix »
I've found someways to catch the caret pos problem! not just this way but this can make it to see:
1) start typing random arabic characters 2) then type a series of numbers then type some random shits again 3) do step (2) once more.
when you set the caret inside the text produced in step (2) by mouse and try to put some chrs, you'll see the difference between the caret pos and typed chrs pos!
( if didn't happened make your likes longer to be wrapped more and try set caret to various places there!)
somethin like this:
ابغلذسیعاباسی باسیب سغلیب 342345234هیبعا هسیبعلسلییببثابفللاقفسیلبلیهل لسیبلبلب 3455665635ل یهعقث ثقب السهیبالیاسباهیعیبا هعا ه یبهل
that was funny :D
viperpix
Waitin..
Post by viperpix »
I'm still waiting....
the Picture D&D problem is more annoying :(
I made some changes in code and I believe this problem is fixed now.
Version 12.8.3 (beta) is available for registered users.
