underlining problem
JohnMirror
underlining problem
Post by JohnMirror »
I found a nice function: AddMisspelling :)
I started experimenting and a problem appeared:
You notice that the underline is out of sync on first word (-1).
This code was used (in ActionTest):
var s: string;
  i, p: Integer;
   for i := 0 to SRichViewEdit1.RichViewEdit.ItemCount - 1 do
      s := SRichViewEdit1.RichViewEdit.GetItemTextA(i);
      p :=  Pos(', supra', s);
      if p = 1 then
         SRichViewEdit1.RichViewEdit.GetItem(i).AddMisspelling(3, 5);
   SRichViewEdit1.RichViewEdit.Invalidate;
In both cases the text item is ", supra". Oh, and if after underlining I insert or delete text around the first word and I change its physical position sometimes the underline becomes synced again. And when I say "change its physical position" I don't mean that inside that item the text will be shifted; the entire item will be shifted.
If I deactivate "Justify" or use an older version of ScaleRichView all is fine.
The rtf that I used is so short that I will add it here:
{\rtf1\ansi\ansicpg0\uc1\deff0\deflang0\deflangfe0\paperw12240\paperh15480\margl1800\margr1800\margt1440\margb1440\headery720\footery720\viewscale100\viewzk0
{\fonttbl{\f0\fnil Arial;}{\f1\fnil\fcharset0 Times New Roman;}{\f2\fnil\fcharset238 Times New Roman;}}{\colortbl;\red0\green0\blue0;\red0\green0\blue255;\red0\green255\blue255;\red0\green255\blue0;\red255\green0\blue255;\red255\green0\blue0;\red255\green255\blue0;\red255\green255\blue255;\red0\green0\blue128;\red0\green128\blue128;\red0\green128\blue0;\red128\green0\blue128;\red128\green0\blue0;\red128\green128\blue0;\red128\green128\blue128;\red192\green192\blue192;}
{\header
\pard\fi0\li0\ql\ri0\sb0\sa0\itap0 \plain \f0\fs20 \par}{\footer
\pard\fi0\li0\qj\ri0\sb0\sa0\itap0 \plain \f1\fs24 I\plain \f2\fs24 mediat ce \u238 \'ee\u351 \'bai lu\u259 \'e3 la bord pasagera, elicopterul se preg\u259 \'e3ti s\u259 \'e3 p\u259 \'e3r\u259 \'e3seasc\u259 \'e3 platforma de pe zg\u226 \'e2rie-nori. Rafalele puternice \u238 \'eengreunau \u238 \'eens\u259 \'e3 decolarea \u351 \'bai, din cauza unei erori de manevrare, o parte a dispozitivului de aterizare se prinse \u238 \'een ancorele care fixau antena de satelit de pe cl\u259 \'e3dire. Deodat\u259 \'e3, supra\u238 \'eentins, cablul p\u226 \'e2r\u226 \'e2i \u351 \'bai se rupse cu un zv\u226 \'e2cnet, \u238 \'eencurc\u226 \'e2ndu-se \u238 \'eentre palele rapide ale elicei.
\par
\par Rafalele puternice \u238 \'eengreunau \u238 \'eens\u259 \'e3 decolarea \u351 \'bai, din cauza unei erori de manevrare, o parte a dispozitivului de aterizare se prinse \u238 \'een ancorele care fixau antena de satelit de pe cl\u259 \'e3dire. Deodat\u259 \'e3, supra\u238 \'eentins, cablul p\u226 \'e2r\u226 \'e2i \u351 \'bai se rupse cu un zv\u226 \'e2cnet\par}
Sorry for delays, I'll answer tomorrow.
It's a bug. It will be fixed in the next update.
JohnMirror
Ok, thank you.
Fixed in version 12.8.1 (beta), available for registered users.
petrica
Post by petrica »
Hi.
I'm currently testing the trial versions (TRichView v12.6.1, RichViewActions v2.2.3, ScaleRichView v3.6.1).
Can you please post the trial version for TRichview 12.8.1 on your site...?
Thank you.
We plan to update trials in the next week.
