Mark text for "tab" stops
agent86
Post by agent86 »
I will be using "canned" text which will be in a dbrichview. There will be multiple places in the paragraph of text that will need editing. The markers will always be in the same places. Is there a demo or is there a way to mark the "canned" text with markers that would give the user the ability to "tab" from marker to marker. I will actually be using F11 to jump from marker to marker.
In the silly example below it would stop at each underscore and you would replace the underscore with a number, hit F11 and it would jump to the next underscore.
There were _ cases of beans. There were _ cases of corn. We moved _ cases of green beans to the stockroom.
May be you just can call SearchText('_', ...) to select the next underscore?
