Table alignment lost
Rogerio
Post by Rogerio »
Oi People!
I am loading a document into the Richviewedit. This document has three tables with diferentes alignment: one in the center, other on the left and the last on the right. When the document is showed, all tables appear aligned on the left. What do I need to do to solver this problem?
Sorry my pauper English.
1. Do you load RTF documents?
2. What version of TRichView?
Rogerio
Post by Rogerio »
I load RTF documents with the follow code:
procedure TItemEditTexts.SetConteudo(value : TStringList);
Var
 St: TStream;
 St := TMemoryStream.Create;
 // mm is a TRichViewEdit
   value.SaveToStream(St);
   St.Seek(0,soBeginning);
   mm.LoadFromStream(St, rvynaAuto);
   mm.FormatTail;
   mm.Format;
   St.Free;
I am using the version 1.9.48.
[/img]
Old version of TRichView did not support loading table alignment from RTF.
It is implemented in newer version.
Please upgrade (send me a private message with information about your order, for example email address that was used in it, and I'll give you a download link for new version)
