Control-I deletes selected text in DBRichView
agent86
Post by agent86 »
I am using the one of the demos. Whn I select text and press Ctrl-I it deletes the selected word. I want to use Control-I to get italics. I've tempoarily set it up to use Ctrl-K to do italics. Any idea why Ctrl-I deletes the selected text? Underline and Bold work great.
// shortcuts for Bold, Underline and Italic
if ( ActiveControl = rve ) then
// Bold
if ( (ssCtrl in Shift) and ( key = ord('B')) ) then
// simulate button press
if btnBold.Down = False then
btnBold.Down := True
btnBold.Down := False ;
rve.ApplyStyleConversion(1); // bold tag
end ;
// italics
if ( (ssCtrl in Shift) and ( key = ord('K')) ) then
if btnItalic.Down = False then
btnItalic.Down := True
btnItalic.Down := False ;
rve.ApplyStyleConversion(2); // italics tag
end ;
// underline
if ( (ssCtrl in Shift) and ( key = ord('U')) ) then
if btnUnderline.Down = False then
btnUnderline.Down := True
btnUnderline.Down := False ;
rve.ApplyStyleConversion(3); // italics tag
end ;
Ctrl+I generates a tab character, you can see it in other editors, for example in Notepad.
So I still suggest to create an action or menu item for this command, and assign Ctrl+I shortcut to it.
agent86
Ctrl-I issue not like MS Word
Post by agent86 »
MS Word uses Crl-I to so italics.
Can I turn off the Ctrl-I = TAB?
It's not TRichViewEdit who converts Ctrl+I to Tab.
It is made by Windows itself, so you cannot disable this conversion.
I suggested a simple solution - if you create an action or menu item with Ctrl+I shortcut, this key combination will be processed before it will be sent to the editor.
Another solution is adding the following code in OnKeyDown and OnKeyPress:
var IgnoreNextTab: Boolean = False;
procedure TForm1.rveKeyDown(Sender: TObject; var Key: Word;
  Shift: TShiftState);
  IgnoreNextTab := (Key=ord('I')) and (Shift=[ssCtrl]);
procedure TForm1.rveKeyPress(Sender: TObject; var Key: Char);
  if IgnoreNextTab and (Key=#9) then
    Key := #0;
  IgnoreNextTab := False;
agent86
Action list solved the problem. Thanks
Post by agent86 »
Is there any documentation on the action items included in the demo?
If you mean RichViewActions and ActionTest demo, all actions are completely documented.
You can find RichViewActions.chm in the zip file.
Or you can use the online manual: http://www.trichview.com/help-actions/
agent86
Action List
Post by agent86 »
Thank you. Exactly what I needed.
