Hi Sergey!
I'm having trouble running the application with the SRICHVIEW on other machines. I compiled my file and installed it on 4 machines. Worked in two and two gave error. This problem may be due to lack of any "dll"? Appeared in a 'Capability not supported' and other 'Printer selected is not valid' when I open the SRICHVIEW. Any idea what could be?
Error with SRICHVIEW
the error "Printer selected is not valid 'I solve it was because there was no printer installed on that computer.
But the error "Capability not supported 'keeps popping up on a machine with Windows XP. I program in a WIndows 7, there may be some connection?
Following happens: whenever you open the form in which it is inserted TSRICHVIEWEDIT appears the error 'Capability not supported' then I tap 'OK' and the program follows the tsrichviewedit opens, runs all the properties, but then closes and opens again when the back error.
What do you think you can be?
