TrvHTMLImporter does not export imported flash???
bozo
Post by bozo »
If I use TrvHTMLImporter to import an html page contaning flash, those tags are not included in the html that I export. Is that right? Am I doing something wrong?
TrvHtmlImporter does not support loading flash, modification of its source code is required for this.
If you inserted flash object in TRichView and want to save it to HTML, you need to write a code for saving it in OnSaveComponentToFile event.
