Is it possible to fix table cell's width ?
jhonalone
Post by jhonalone »
I need fix width for some cells into a table, how can I do?
table.BestWidth := -100;
table.MergeCells(0,0,NumCols div 2,7, True);
table.SetCellVisibleBorders(False, False, False, False, 0,0);
table.Rows[0][0].Clear;
     pic := TjpegImage.Create;
     pic.LoadFromFile('Logo.JPG');
     table.Cells[0,0].AddPictureEx('', pic, 0, rvvaMiddle);
I insert a TJpegImage into a merged cell.
The padding of merged cell is enlarged inexplicablely.
The cell size is enlarged.
If, at running, I contract image, more and more, then the cell reduce size also to a point. If I continue contracting image, I find a point that cell do not reduce size.
Can I adjust the image size to cell size whitout change cell size?
Thank you for your time.
What version of TRichView do you use?
jhonalone
Post by jhonalone »
I`m using the 1.9.48 version. Sorry.
The problem in table sizing algorithm (too large width for merged table cells containing pictures or other wide objects) must be solved in newer version. I do not remember the version number where it was solved, sorry.
If you are the registered user, the most probably you can get the newest version for free (or at least version 11.1.1, it depends on the time where you registered).
Please send me details of your order in a private message (such as email address that might be in your order, or your full name), and I'll give you a link for free upgrading.
I found, this problem was fixed in version 12.4.5 (released in 2010-Aug-7)
jhonalone
Post by jhonalone »
OK, Sergey. I'll send you a private message with register date and my full name.
Thanks.
