pre-sales querstions
EdDressel
Post by EdDressel »
I have a few questions about features:
1) Can files be easily merged?
2) Has there ever been a solution to get the TRichView to work in a DevExpress TcxGrid?
3) Does it work with Addict Spell Checker (v. 4)?
4) Are there any known issues work with the Report Builder plugin?
Thank you,
Ed Dressel
EdDressel
Post by EdDressel »
5) Are style sheets supported?
1) Do you mean adding one document to the end of another document, or something different?
2) There is a beta version available to registered users. Full functional, but it does not support ExpressPrintSystem yet. I'll send you a link in a private message.
3) Yes, it works. Download and install additional components http://www.trichview.com/resources/adrv3/adrv3.zip (they work both with Addict 3 and 4)
4) No known problems. For ReportBulder 9-12, use http://www.trichview.com/resources/repo ... uilder.zip
Not all packages are available, for some versions of Delphi, you need to create them yourself (create a new package and add all pas-files of this wrapper to them)
5) Like in MS Word? Not yet, sorry.
