1. When I start the richview font is Arial and font size is 10. How can I set the starting font and font size when opening the form that contains the dbrichview?
2. How can I find the current position of the cursor. I want to display it in the status bar. Iw ant line number and column position.
Starting Font and Font size, also show position of cursor
1) Assuming that you use TDBRichViewEdit in mode what allows adding styles, you can use TDBRichViewEdit.OnNewDocument to create a default set of styles:
// assuming that DBRichViewEdit1.Style = RVStyle1
procedure TForm1.DBRichViewEdit1NewDocument(Sender: TObject);
RVStyle1.TextStyles.Clear;
with RVStyle1.TextStyles.Add do begin
FontName := 'Times New Roman';
RVStyle.ParaStyles.Clear;
RVStyle.ParaStyles.Add;
RVStyle.ListStyles.Clear;
