How Can I Build a Style Programatically ?
andyhill
Post by andyhill »
How Can I Build a Style Programatically and use when inserting line (need to use TextStyle with Bold Attribute) ?
rvs2.ResetTextStyles;
rvs2.ResetParaStyles;
rvs2.TextStyles.AddFont('Times New Roman', 12, clBlack, clWhite, [want bold]);
rvs2.ParaStyles.Add;
rvs2.ParaStyles[0].Alignment:= rvaCenter;
rve2.Style:= rvs2;
rve2.Clear;
rve2.AddNL('Test 1', 0, 0);
rve2.AddNL('Test 2', 0, 0);
rve2.AddNL('', 0, 0);
rve2.AddNL(ClientName, 0, 0);
rve2.AddNL('CLIENT NOTES', 0, 0);
Fails to use my TextStyle ?
append other rve's here
andyhill
Merge rve streams and files
Post by andyhill »
function TfRichView.RVCopy(RVSource, RVDest: TCustomRichView): Boolean;
MyStream: TMemoryStream;
MyStream:= TMemoryStream.Create;
RVSource.SaveRVFToStream(MyStream, False);
MyStream.Position:= 0;
Result:= RVDest.InsertRVFFromStream(MyStream, RVDest.ItemCount);
RVDest.FormatTail;
except
Result:= False;
MyStream.Free;
PrintIt:= psd.Execute;
if PrintIt then begin
ClientName:= '';
case fMain.Table0.FieldByName('Gender').AsInteger of
1: ClientName:= 'Mr ';
2: ClientName:= 'Mrs ';
3: ClientName:= 'Ms ';
4: ClientName:= 'Miss ';
ClientName:= ClientName+fMain.Table0.FieldByName('FirstName').AsString+' '+fMain.Table0.FieldByName('LastName').AsString;
// Clear rvs2 Styles
// Add Text Style for heading
rvs2.TextStyles.AddFont('Times New Roman', 12, clBlack, clWhite, []); // !!! I Want Bold ?
// Add Paragraph Styles
rvs2.ParaStyles[1].Alignment:= rvaLeft;
// Assign rvs2
rve2.Style:= rvs2;
rve2.Clear;
// Add text
rve2.AddNL('Business Name', 0, 0);
rve2.AddNL('Business Address', 0, 0);
// Append rve to rve2
RVCopy(rve, rve2);
// Add Table to rve2
table:= TRVTableItemInfo.CreateEx(3, 1, rve2.RVData);
table.BorderStyle:= rvtbRaisedColor;
table.CellBorderStyle:= rvtbLoweredColor;
table.BorderWidth:= 1;
table.CellBorderWidth:= 1;
table.CellPadding:= 5;
table.CellVSpacing:= 1;
table.CellHSpacing:= 1;
table.BorderVSpacing:= 1;
table.BorderHSpacing:= 1;
// Size table
for r:= 0 to table.Rows.Count-1 do begin
for c:= 0 to table.Rows[r].Count-1 do begin
table.Cells[r, c].BestWidth:= 700; // !!! I want page width
{ !!! I want to add rve3 stream, rve4 file and rtf file into this table (3 rows [one per item]) ?
// Row 1
if r = 0 then begin
with table.Cells[r, 0] do begin
Color:= clInfoBk;
Clear;
RVCopy(rve3, rve2); // !!! NOT THIS WAY ???
// Add table to rve2
rve2.AddItem('', table); // !!! I want to add table Left Aligned ?
// Assign to rvprint
RVPrint1.AssignSource(rve2);
// Set margins
RVPrint1.LeftMarginMM:= 10;
RVPrint1.RightMarginMM:= 10;
RVPrint1.TopMarginMM:= 10;
RVPrint1.BottomMarginMM:= 10;
// Format
RVPrint1.FormatPages(rvdoALL);
// Print
if RVPrint1.PagesCount > 0 then RVPrint1.Print('LBAnalysis', 1, False);
ResetTextStyles and ResetParaStyles do not clear styles. They assign default styles to them (styles that you can see when you place a new TRVStyle component on the form).
Use
rvs2.TextStyles.Clear;
rvs2.ParaStyles.Clear;
andyhill
Post by andyhill »
Thank you Seregy.
You did not explain:-
1) How to add Bold Attribute to text style ?
2) How to select Text Attribute when using ADDNL ?
3) How to insert rv stream/file into table cell, either during table construction -or- locating table and cell in editor ?
andyhill
Insert RVF File into Table Cell Programatically
Post by andyhill »
rve2.AddItem('MyTempTable', table);
for i:= 0 to rve2.TopLevelEditor.ItemCount -1 do begin
ItemInfo:= rve2.TopLevelEditor.GetItem(i);
if ItemInfo.ItemText = 'MyTempTable' then begin
ItemNo:= rve2.TopLevelEditor.GetItemNo(ItemInfo);
Offs:= rve2.TopLevelEditor.GetOffsBeforeItem(ItemNo);
rve2.TopLevelEditor.SetSelectionBounds(ItemNo, Offs, ItemNo, Offs); // FAILS (I want to select ROWn, CELLn)
rve2.TopLevelEditor.InsertRVFFromFileEd('D:\D2011\Editor\test.rvf');
Well, it's much easier to answer to questions that were asked :)
1) Specify Style=[fsBold]. You can use AddFont, or just Add and then assign properties, for example:
with rvs2.TextStyles.Add do begin
  FontName := 'Times New Roman';
  Color := clBlack,
  BackColor := clWhite,
  Style := [fsBold];
2) rve2.AddNL has StyleNo parameter - index in rvs2.TextStyles (assuming that rve2.Style = rvs2). You use 0 in your first code sample, so all text is added using rvs2.TextStyles[0]. If you change ResetTextStyles to TextStyles.Clear, then rvs2 will have only one text style, added by AddFont, and your code will use this style.
3) If you want to load RVF to a cell, there a problem: cells do not support loading RVF containing text/paragraph/list styles. A workaround is shown in this demo: http://www.trichview.com/support/files/copyfromcell.zip
However, if you want to use editing method for inserting RVF in the caret position, it's no problem.
In your code, you insert the table directly in rve2:
So, when searching for this table, you need to use methods of rve2, not rve2.TopLevelEditor. Otherwise, if the caret is in a table cell, the code searches in this table cell.
var i: Integer;
  table: TRVTableItemInfo;
  RVData: TCustomRVFormattedData;
for i:= 0 to rve2.ItemCount -1 do
  if (rve2.GetItemStyle(i)=rvsTable) and (rve2.GetItemText(i)='MyTempTable') then begin
    table := TRVTableItemInfo(rve2.GetItem(i));
    // 1. Before working with selection in a table cell, activate its editing.
    // It can be done by table.EditCell or by Cell.Edit.
    table.EditCell(ROW, COLUMN);
    // 2. Cell is in an editable state.
    // However, the caret is not necessary inside it.
    // It may be in a cell of some table inside this cell.
    // Moving the caret to the beginning of this cell
    RVData :=  TCustomRVFormattedData(table.Cells[ROW, COLUMN].GetRVData);
    RVData.SetSelectionBounds(0, RVData.GetOffsBeforeItem(0), 0, RVData.GetOffsBeforeItem(0));
    // 3. Now the caret is in our cell, so rve2.TopLevelEditor edits this cell.
