Repeat image at higher resolution
gully
Post by gully »
Hello Sergey
If the resolution is larger than 1200px, then repeats the image of the RPF template. How can I prevent this recurrence.
Good luck in the new year! :D
Only by making the background picture wider.
In the current version of TRichView, there is no way to specify to repeat a background picture only vertically. It is repeated both vertically and horizontally.
gully
Post by gully »
thanks for the reply. it would be possible to implement this feature in a future release TRichView?
Yes, but I cannot tell when it will be implemented
gully
Post by gully »
thank you :D
gully
Post by gully »
Hello Sergey.
Any news about this problem?
Thanks for Your answer.
Sorry no. At least not in this Summer.
It may look simple, adding these options. But I do not like the idea of adding too many options in BackgroundStyle.
Even for adding vertical tiling, it would be 6 new options:
(fixed tiles | scrolled tiles) x (left-aligned | centered | right-aligned)
So I think it makes sense to change background only when we decide to rework it completely: changing a set of properties for background (separate properties for vertical and horizontal positioning, different image types, gradients, etc.)
gully
Post by gully »
ok. I agree. and plan to do? resolution is becoming higher ...
I still not sure. Probably we still decide to add these 6 new values in BackgroundStyle before making radical changes.
