BDS 2006
jma
BDS 2006
Post by jma »
Is it supported yet (C++ in my case)
I'm looking for upgrading so I would like to know if its supported
or if I could use the current packages in BDS 2006.
C++ and Win32 Delphi personalities are supported.
A minor change is required to the latest TRichView version to be used in D2006 C++Builder. If newer version will not be uploaded when you upgrade to D2006, contact me.
Guest
Post by Guest »
Well D2006 is out, so where can I get richview from?
SESummers
Post by SESummers »
Sergey Tkachenko wrote:C++ and Win32 Delphi personalities are supported.
I just got my copy, and plan to rewrite an older application (using WPTools) with RichView (using the new Delphi) over Christmas vacation, so I'd like the update as soon as practical.
Thanks.
Version with packages for D2006 will be available for registered users in this week end.
