I have been using TDBRichView without problems
I now need to load a TRichView component from same blob field that I have been using with TDBRichView
The code I am using is as follows:
BlobStream := MyQuery.CreateBlobStream(MyQuery.FindField('SummaryDescription'), bmRead);
txtSummaryDescription.LoadTextFromStream(BlobStream, 0, 0, False);
txtSummaryDescription.Format;
except
FreeAndNil(BlobStream);
I get rubbish in the control even though the content is same as I was loading with TDBRichView
I have an RVStyle compoennt associated with the TRichView component
The content was originally created in MS Word and pasted into the TDBRichView component
Problem loading from blob field
Problem solved
For some reason the following code works but not sure why my original code did not.
BlobStream := TMemoryStream.Create;
TBlobField(MyQuery.FindField('SummaryDescription')).SaveToStream(BlobStream);
BlobStream.Position := 0;
txtSummaryDescription.LoadFromStream(BlobStream, rvynaNo);
except
except
