When using a gif image as background for a table cell the size of the image is doubled every time the document is saved as RVF. I saved the image externally to check it and it seems that the number of layers was doubled on each save.
I'm using RichViewEdit 11.1.1, RichView actions 1.72 and Delphi 2007.
For the GIF support I'm using the GIFImg unit from http://cc.embarcadero.com/item/25696.
Is this something that is solved in later versions of RichViewEdit?
GIF background image size doubled on each save
Fixes for TGifImage are sent in a private message. Clarification again: these fixes only for GifImg.pas for Delphi 2007 and 2009. Thirdparty GifImage.pas does not need these fixes. GifImg.pas for Delphi 2010 and XE does not need fixes as well.
Registered TRichView users can read this information in the protected "Examples, Demos" forum.
There are no similar problems with PNG images.
