Hi there
I need to add a Hypelink to my Editor.
I want the user to select a some text.
Press a button, brings up a little customized screen.
After that, it build up a string, and create the hyperlink using the selected text and the build-up string.
Michael
HYPERLINK Help needed
1) http://www.trichview.com/forums/viewtopic.php?t=61
2) You can use RichViewActions http://www.trichview.com/resources/actions/
