Substitute RichViewEdit in TSRichViewEdit
vit
Post by vit »
Hi!
I whant write descendant to TRichViewEdit and override several methods. And futher I'm going to substitute standart TRichViewEdit by it in TSRichViewEdit.
Can I use ExternalRV property for this purpose?
I can't understand how exactly use it. Wich properties of external RVE I should set?
Example
  ExRVE: TRichViewEdit;
  ExRVE := TMyRichViewEdit.Create(Self);
  ExRVE.Style := RVS;
  SRVE.ExternalRV := ExRVE;
It doesn't work becouse ExRVE.Parent is not assigned. Can you please give me example of using ExternalRV?
Thank you!
vit
Post by vit »
Ok, I found now \Demos\Basic Demos\External RichView
As I see ExternalRV is not for substituting of editors of TSRichViewEdit... And is no other ways to substitute TSRichViewEdit? I mean that new RVE should be inside TSRichViewEdit instead of usual RichViewEdit, not somewhere at the side..
vit
Post by vit »
Or if it is impossible may be there is a way to substitute RVData of TRichViewEdit? Becouse it also contains virtual methods wich I whant override.
To change RVData class, override GetDataClass method of TRichViewEdit. Of course, it requires creating a component inherited from TRichViewEdit or TCustomRichViewEdit.
However, when editing a table cell, an inplace editor is created. This editor has TRVTableInplaceEdit class and cannot be changed. It has its own RVData of TRVTableInplaceRVData class.
As for TSRichViewEdit, there are two methods for changing its RichViewEdit.
First, using external TRichViewEdit. It must be placed on a form, but should be hidden. This external editor can be used instead of the build-in editor.
Second, you can create a component inherited from TSRichViewEdit and override CreateRichViewEditObject method.
vit
Post by vit »
Thank you for answer.
Sergey Tkachenko wrote: First, using external TRichViewEdit. It must be placed on a form, but should be hidden. This external editor can be used instead of the build-in editor.
There is one strange thing.
When I did this:
1. Added TSRichViewEdit on the form (SRVE)
2. Added TRVStyle on the form (RVS)
3. Added TRichViewEdit on the form (RVE) (below SRVE)
4. Assigned SRVE.ExternalRVStyle to RVS
5. Assigned RVE.Styles to RVS
6. Maked RVE invisible
7. Assigned SRVE.ExternalRV to RVE
8. Compiled and runed application
9. Typed some text
10. Performed text drag drop with copying
Invisible RVE was showed. Is this bug or I did something wrong?
I discussed this situation with Ilya, he said that it is unavoidable.
He suggest to place this RichViewEdit on a TPanel, then set the size of this panel 0x0
vit
Post by vit »
When I do it in designtime all works fine. But in runtime SRVE looks like this:
It seems like RVE was placed at left field of page.
There is the code:
  RVE: TRichViewEdit;
  RVE := TMyRVE.Create(SRVE);
  RVE.Style := RVS;
  SRVE.ExternalRV := RVE;
  RVE.Visible := False;
  RVE.Parent := Panel1;
What should I do to assign external RVE correct in designtime?
Tahnk you!
proxy3d
ScaleRichView Developer
Post by proxy3d »
need to apply the properties of SRV to RV, using RefreshData
  SRVE.RefreshData;
