Processing OleDragDrop
vit
Post by vit »
Hi!
When user drags text from one place of document to another I whant to known what exactly he drags. I whant to analyse content and probably modify them before insert. It is important that I whant analyse exactly content in RVF format.
So I get as base this http://www.trichview.com/forums/viewtop ... dataobject topic and write OnOleDrag event handler:
(AcceptDragDropFormats is [rvddRVF])
procedure TForm1.RVEOleDrop(Sender: TCustomRichView;
  const DataObject: IDataObject; Shift: TShiftState; X, Y: Integer;
  PossibleDropEffects: TRVOleDropEffects; var DropEffect: TRVOleDropEffect;
  var DoDefault: Boolean);
var FmtEtc: TFormatEtc;
  StgMedium: TStgMedium;
  ptr: Pointer;
  s: String;
  p: Integer;
  ms: TMemoryStream;
  DoDefault := False;
  FillChar(StgMedium, sizeof(StgMedium), 0);
  FillChar(FmtEtc, sizeof(FmtEtc), 0);
  //FmtEtc.cfFormat := CF_TEXT;
  FmtEtc.cfFormat := CFRV_RVF;
  FmtEtc.dwAspect := DVASPECT_CONTENT;
  FmtEtc.lindex := -1;
  FmtEtc.tymed := TYMED_HGLOBAL;
  if DataObject.GetData(FmtEtc, StgMedium)<>S_OK then
  if StgMedium.tymed=TYMED_HGLOBAL then begin
    ptr := GlobalLock(StgMedium.HGlobal);
      SetLength(s, GlobalSize(StgMedium.HGlobal) div sizeof(Char));
      Move(ptr^, PChar(s)^, Length(s)*sizeof(Char));
      ms := TMemoryStream.Create;
        ms.Write(PChar(s)^, Length(s));
        ms.Position := 0;
        if not RVE.InsertRVFFromStreamEd(ms) then
          ShowMessage('Can''t insert RVF!');
        ms.Free;
      GlobalUnlock(StgMedium.HGlobal);
  ReleaseStgMedium(StgMedium);
First I always seen message 'Can't insert RTF!'. After researches I found that first 4 bytes of S contains length of RVF data. Is it correct? And should I use this value to read data from ms? Or may be I can just read data until the end?
Also as you can see, I use CFRV_RVF to retreive data. Is it correct? Or I should use CF_TEXT insead (I never use Unicode).
And last. This code will work only when data is in RVF format. Can I be sure that if text dragged from TRichViewEdit it will be always in RVE? I guess that if data is not in RVF then
will be true
Thank you!
For RVF, the first 4 bytes contains size (in bytes) of RVF content.
procedure TForm3.RichViewEdit1OleDrop(Sender: TCustomRichView;
  ptr: Pointer;
  ms: TMemoryStream;
  DoDefault := False;
      if GlobalSize(StgMedium.HGlobal)>4 then begin
        Size := PInteger(ptr)^;
          ms.WriteBuffer((PRVAnsiChar(ptr)+sizeof(Integer))^, Size);
          ms.Position := 0;
          if not TCustomRichViewEdit(Sender).InsertRVFFromStreamEd(ms) then
          ms.Free;
