i saved the rvf stream of Trichvieweditor in a database, then i want to search some string in the rvf stream loaded from the database, how can i do it ?
thanks
how can i search a string in RVF file or RVF stream?
It's not possible without loading document in TRichView.
For example:
For example:
// rv is TRichView
var Stream: TStream;
Stream := Table.CreateBlobStream(Table.FieldByName(FieldName), bmRead);
Result := rv.LoadRVFFromStream(Stream);
Stream.Free;
// rv.Format is not called, otherwise it would be too slow.
Result := HasWord(rv.RVData, WordToSearch);
uses CRVData, RVTable;
function HasWord(RVData: TCustomRVData; const WordToSearch: String): Boolean;
var i,r,c: Integer;
s: String;
table: TRVTableItemInfo;
Result := False;
if RVData.GetItemStyle(i)>=0 then
begin // this is a text item
s := RVData.GetItemTextA(i);
Result := AnsiPos(WordToSearch, s)>0;
if Result then
end
else if RVData.GetItemStyle(i)=rvsTable then
if table.Cells[r,c]<>nil then
Result := HasWord(table.Cells[r,c].GetRVData, WordToSearch);
if Result then
