align a table created from a tab separated stringlist
jclaes
Post by jclaes »
I was able to create a table using following code
     Table := TRVTableItemInfo.CreateEx(Rows, Cols, RVData);
     Table.BorderWidth := 0;
     Table.CellBorderWidth := 0;
     for RowCounter := 0 to Fields.Count-1 do
       for ColCounter := 1 to Cols do
         Table.Cells[RowCounter,ColCounter-1].SetItemText(0,GetPiece(Fields[RowCounter],#9,ColCounter,ColCounter));
The header row is always centered and bold and than the data rows are
dynamicully provided as a tab separated string like Left#9Right#9Right#9Left
You cannot include #9 in the item text.
Instead of
Cell.SetItemText(0, s)
use
Cell.Clear;
Cell.AddTextNL(s, 0, 0, 0);
jclaes
Post by jclaes »
The text is not the problem it is the alignment of the cells that's is the problem. I want to parse a stringlist that has the alignment of each cell as text in it.
Item[0] := Center#9Center#9Center#9Center
Item[1] := Left#9Right#9Left#9Center
Each new item of the ItemList is the row of the table and each part of the #9 seperated string is the alignment.
So the second row of the table the 1st cell is left aligned the 2nd right aligned the 3rd left and the 4rd centered
Is their an easy why to align a cell ? For example table.cells[row,col].aligment = leftjustify ..
Horizontal text alignment is a property of paragraph, not a cell.
You can place left-, right- and centered paragraphs in RVStyle.
To assign paragraph index to item, use:
Table.Cells[RowCounter,ColCounter-1].GetItem(0).ParaNo := ...
