SRichViewEdit & FastMM4
Hi!
I try to implement some application using SRichViewEdit but FastMM4 has detected memory using troubles.
In general application represents form with TPageControls and two buttons - "Add" and "Delete". When user push "Add" button the new page with TMyFrame is added to TPageControl. "Delete" button delete active page (with destroying TMyFrame).
TMyFrame - is frame I make for error demonstration purposes. I just open a form Demos\ActionTest\Unit3.pas (from srv_demos.zip), select and copy all components from this form, and then paste its in TMyFrame. Besides, I add dmActionsSRV.pas (from same demo project) to my project.
So, user can add and delete pages with cool text editors.
But FastMM4 (in FullDebugMode) detects memory error! To reproduce this error is needed to push "add" twice, then "delete" then "add" again.
I have prepare test project you can download its from
http://webfiles.ru/control/?file_id=191 ... 89c06149b8
Besides you can download my FastMM4Options.inc from here http://webfiles.ru/control/?file_id=191 ... a939e4d11e
It looks like error not appear if delete SclRVRuler1 from TMyFrame.
Any suggestions?
Any suggestions?
Yes, I have delete all files of old versions.Sergey Tkachenko wrote:Sorry, we cannot reproduce it. We tried in D5,6,7,2007, no crashes.
May be your application is still compiled with old files? Did you delete old versions when installing new versions of controls?
I click several times to add/del buttons and once when I click "add" FastMM throws message:
Project1.exe: Memory Error Detected
FastMM has detected an error during a GetMem operation. FastMM detected that a block has been modified after being freed.
Modified byte offsets (and lengths): 14(1)
The previous block size was: 108
This block was previously allocated by thread 0xF34, and the stack trace (return addresses) at the time was:
402A23 [System][@GetMem]
403B23 [System][TObject.NewInstance]
403EFE [System][@ClassCreate]
53922E [RVThread.pas][RVThread][TRVWordEnumThread.Create][101]
52EEE0 [RichView.pas][RichView][TCustomRichView.StartLiveSpelling][3637]
4F265E [RVEdit.pas][RVEdit][TCustomRichViewEdit.DoChange][2626]
4F2682 [RVEdit.pas][RVEdit][TCustomRichViewEdit.Change][2636]
69C68D [RVRuler.pas][RVRuler][TRVRuler.DoMarginChanged][374]
6A0B21 [SclRVRuler.pas][SclRVRuler][TSclRVRuler.DoMarginChanged][707]
5B268F86 [Unknown function at IsThemeActive]
403D81 [System][@CallDynaInst]
6979C7 [Ruler.pas][Ruler][TCustomRuler.SetRightMargin][5660]
69DAA6 [RVRuler.pas][RVRuler][TRVRuler.UpdateRulerMargins][819]
69D331 [RVRuler.pas][RVRuler][TRVRuler.RichViewEditResize][651]
69D358 [RVRuler.pas][RVRuler][TRVRuler.RichViewEditResize][654]
5A26DB [RVScroll.pas][RVScroll][TRVScroller.DoAfterResize][797]
5A1C16 [RVScroll.pas][RVScroll][TRVScroller.UpdateScrollBars][525]
53B94B [RVRVData.pas][RVRVData][TRichViewRVData.SetDocumentAreaSize][877]
545213 [CRVFData.pas][CRVFData][TCustomRVFormattedData.Format_][3291]
545391 [CRVFData.pas][CRVFData][TCustomRVFormattedData.Format_][3327]
676428 [SclRView.pas][SclRView][TSRichViewEdit.GetClientRect][11672]
69E029 [RVRuler.pas][RVRuler][TRVRuler.UpdateTableEditor][967]
6A0D00 [SclRVRuler.pas][SclRVRuler][TSclRVRuler.DoMarginChanged][739]
5B27E615 [Unknown function at DrawThemeEdge]
4E1E30 [RVERVData.pas][RVERVData][TRVEditRVData.Format_][4790]
46A448 [Controls.pas][Controls][TControl.GetClientHeight][3491]
The block was previously used for an object of class: TRVWordEnumThread
The allocation number was: 82460
The block was previously freed by thread 0x474, and the stack trace (return addresses) at the time was:
402A43 [System][@FreeMem]
403B41 [System][TObject.FreeInstance]
403F49 [System][@ClassDestroy]
53929D [RVThread.pas][RVThread][TRVWordEnumThread.Destroy][111]
403B87 [System][TObject.Free]
427579 [Classes][ThreadProc]
408FC8 [FastMM4.pas][FastMM4][FastFreeMem][4566]
404946 [System][ThreadWrapper]
7C80B713 [Unknown function at GetModuleFileNameA]
The current thread ID is 0xF34, and the stack trace (return addresses) leading to this error is:
40A589 [FastMM4.pas][FastMM4][DebugGetMem][6775]
403B58 [System][TObject.Create]
433779 [Graphics.pas][Graphics][TBitmap.NewImage][5782]
433790 [Graphics.pas][Graphics][TBitmap.NewImage][5784]
4336BA [Graphics.pas][Graphics][TBitmap.NewImage][5764]
432975 [Graphics.pas][Graphics][TBitmap.CopyImage][5333]
434430 [Graphics.pas][Graphics][TBitmap.SetPixelFormat][6211]
68D7E0 [Ruler.pas][Ruler][TCustomRuler.Create][2158]
69BFF4 [RVRuler.pas][RVRuler][TRVRuler.Create][198]
69EF20 [SclRVRuler.pas][SclRVRuler][TSclRVRuler.Create][102]
42337C [Classes][CreateComponent]
4235AA [Classes][TReader.ReadComponent]
422D4E [Classes][TReader.EndOfList]
4237F6 [Classes][TReader.ReadDataInner]
423764 [Classes][TReader.ReadData]
427E46 [Classes][TComponent.ReadState]
469BD6 [Controls.pas][Controls][TControl.ReadState][3273]
46E3C1 [Controls.pas][Controls][TWinControl.ReadState][5381]
423615 [Classes][TReader.ReadComponent]
Current memory dump of 256 bytes starting at pointer address 7FF7A6A0:
3C CD 6C 00 3C D0 6C 00 3C D0 6C 00 3C D0 00 00 3C D0 6C 00 3C D0 6C 00 3C D0 6C 00 3C D0 6C 00
3C D0 6C 00 3C D0 6C 00 3C D0 6C 00 3C D0 6C 00 3C D0 6C 00 3C D0 6C 00 3C D0 6C 00 3C D0 6C 00
3C D0 6C 00 3C D0 6C 00 3C D0 6C 00 D0 84 0A 42 3C D0 6C 00 3C D0 6C 00 00 00 00 00 A1 4B F7 7F
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D9 9C 00 00 23 2A 40 00 23 3B 40 00 FE 3E 40 00
46 C2 42 00 88 56 47 00 60 16 5A 00 EA 5B 68 00 0D A6 40 00 3A A6 40 00 7C 33 42 00 AA 35 42 00
4E 2D 42 00 F6 37 42 00 35 37 42 00 46 7E 42 00 D6 9B 46 00 C1 E3 46 00 24 45 42 00 6B 1E 42 00
08 EC 41 00 92 ED 41 00 FF 4B 44 00 A6 C7 46 00 52 5E 7F 00 75 2C 38 7E 52 5E 7F 00 FB 95 40 00
< Í l . < Ð l . < Ð l . < Ð . . < Ð l . < Ð l . < Ð l . < Ð l .
< Ð l . < Ð l . < Ð l . < Ð l . < Ð l . < Ð l . < Ð l . < Ð l .
< Ð l . < Ð l . < Ð l . Ð „ . B < Ð l . < Ð l . . . . . ¡ K ÷
. . . . . . . . . . . . . . . . Ù œ . . # * @ . # ; @ . þ > @ .
F Â B . ˆ V G . ` . Z . ê [ h . . ¦ @ . : ¦ @ . | 3 B . ª 5 B .
N - B . ö 7 B . 5 7 B . F ~ B . Ö › F . Á ã F . $ E B . k . B .
. ì A . ’ í A . ÿ K D . ¦ Ç F . R ^ . u , 8 ~ R ^ . û • @ .
ÎÊ
Debugger Exception Notification
Project SRVEMemoryCrash.exe raised exception class EOutOfMemory with message 'Out of memory'. Process stopped. Use Step or Run to continue.
OK Help
I still cannot reproduce this problem.
Try the following change:
In RVThread.pas: delete the line
In RichView.pas, in procedure TCustomRichView.ClearLiveSpellingResults, add
after
Try these changes and inform me if they fixed the problem.
FreeOnTerminate := True;
FWordEnumThread.Free;
FWordEnumThread.Finish;
Please do one more test.
With this FreeOnTerminate := True in RVThread.pas, change in RichView.pas:
procedure TCustomRichView.ClearLiveSpellingResults;
var Thread: TRVWordEnumThread;
if FWordEnumThread<>nil then begin
Thread := FWordEnumThread;
FWordEnumThread := nil;
Thread.Free;
DoClearLiveSpellingResults;
FullInvalidate;
No, this works worse.
I need note that test application wich I sent you is not pretty correspond to my application wich I develop. SRVEMemoryCrash start work fine when I updated components and changed code as you said first. But my main application still generating exception.
And when I change code as you said in last post SRVEMemoryCrash starts throw exception again (main application has no visible changes).
