I am trying to have a RVE select all text when the user clicks in it (i use one as a one-line editor).
If i write RVE.SelectAll at the OnEnter event, RVE will flash momentarily with the selection, and then lose it.
I tried putting a 'PostMessage' there but it does not work either.
Any help pls?
TIA
Costas
How to select all text when user clicks a RVE?
If I exclude rvoWantTabs from rve.EditorOptions, and add rve.SelectAll in rve.OnEnter, then if you change the input focus using tabs, it is selected on focusing. However, when the focus is moved with the mouse, it is deselected when the mouse button is released.
Talking about the standard behavior, I noticed that it is different for TEdit and TComboBox.
TEdit is selected only if the focus is moved with the keyboard.
TComboBox (including IE's address bar) is selected both with mouse and the keyboard.
To simulate TEdit's selection, you can write:
This code selects only if the focus is obtained when the left mouse button is not pressed (well, the user can hold this button and press Tab, but it is a rare exception).
Unfortunately, simulating TComboBox is more difficult, I cannot give a solution right now...
procedure TForm1.RichViewEdit1Enter(Sender: TObject);
var KeyboardState: TKeyboardState;
GetKeyboardState(KeyboardState);
if KeyboardState[VK_LBUTTON] and $80 = 0 then
RichViewEdit1.SelectAll;
May be this is a not elegant, but it looks like it works:
FocusedWithMouse is a form's Boolean field, it equals to False initially.
function TForm1.IsPressed(rve: TControl): Boolean;
pt: TPoint;
Result := (KeyboardState[VK_LBUTTON] and $80 <> 0);
if Result then begin
GetCursorPos(pt);
pt := rve.ScreenToClient(pt);
Result := (pt.x>=0) and (pt.y>=0) and (pt.x<=rve.ClientWidth) and
(pt.y<=rve.ClientHeight);
FocusedWithMouse := IsPressed(Sender as TControl);
(Sender as TRichViewEdit).SelectAll;
procedure TForm1.RichViewEdit1RVMouseUp(Sender: TCustomRichView;
Button: TMouseButton; Shift: TShiftState; ItemNo, X, Y: Integer);
if FocusedWithMouse then begin
Sender.SelectAll;
Sender.Invalidate;
FocusedWithMouse :=False;
