SaveRTFToStream problem
MichaelV
Post by MichaelV »
Hallo Sergey,
there is a problem with this method.
When i save the content od a TRichview to a stream, the header footer section is missing.
If i save the same content to a file it works fine, can you correct this?
Michael
It is fixed in the latest version available for registered users.
MichaelV
Post by MichaelV »
Sergey Tkachenko wrote:It is fixed in the latest version available for registered users.
ok i will get this, thank you
