Urgent help, i am trialing the components, but have a mjor problem.
I develop Outlook com addins using Delphi 2010 and have run into a major problem with your control.
I have my own custom forms written using Addin Express and Delphi 2010, I have one of your RichViewEdit controls on the form. If I load this in Outlook all works well, pasting images, saving laoding etc, everything I want, but if I try to move the form with your richviewedit control the system goes paralitic, Outlook.exe process uses 100% CPU (or core), the only way I can get anything back is to CTRL+ALT+DEL and kill the Outlook.exe process. I can't debug, because I only the test version of the controls. So what to do? If I purchase and the issue still exists the control is of no use to me.
Any suggestions?
The Com addins are DLLS's running the in the Outlook process.
100% CPU when moving form with RichViewEdit
