Clipboard open during execution of OnChange event
markussamuelsson
Post by markussamuelsson »
Sergey,
We have found a subtle bug in TCustomRichViewEdit.PasteRVF.
The problem is caused by Clipboard.Close being called after InsertRVFFromStreamEd(Stream) in combination with showing a MessageBox (or doing any time consuming operation) in the OnChange event.
InsertRVFFromStreamEd triggers the OnChange event where we pop up the MessageBox. While the MessageBox is still open the Clipboard hasn’t been closed, so if the user switches to another application, e.g. a text editor, he can’t do any copy/paste. The call to OnChange can take an arbitrary amount of time, depending on what is implemented here.
The bug is resolved by calling Clipboard.Close before InsertRVFFromStreamEd(Stream).
Current code causing the undesired behavior:
procedure TCustomRichViewEdit.PasteRVF;
  if not Clipboard.HasFormat(CFRV_RVF) then exit;
  Clipboard.Open;
  Stream := TRVMemoryStream.Create;
    Stream.Position := SizeOf(Size);
    InsertRVFFromStreamEd(Stream);  		<-- Here OnChange is called, while Clipboard is still open
    Stream.Free;
    Clipboard.Close;
Suggested changes:
    Clipboard.Open;
      Clipboard.Close;
    InsertRVFFromStreamEd(Stream);	<-- OnChange is called. Clipboard is closed and can be used by other applications
    Stream.Free;
The same problem and solution applies to TCustomRichViewEdit.PasteGraphicFiles and TCustomRichViewEdit.PasteRTF.
Regards,
Markus Samuelsson
Ok, this change will be included in the next update.
