Text from Edit to itemtext in table
Roman2807
Post by Roman2807 »
My code:
procedure TForm8.Edit2Change(Sender: TObject);
var t : TRVtableitemInfo;
    s : trvtextiteminfo;
    i, i1 : integer;
  t := (SRichViewEdit1.RichViewEdit.RVData.Items.Objects[0] as TRVtableItemInfo);
  t.Cells[0, 0].SetItemText((sender as tedit).Tag, (sender as tedit).Text);
  t.EditCell(0, 0);
  SRichViewEdit1.RichViewEdit.SetFocus;
  edit2.SetFocus;
  Edit2.SelLength := 0;
  edit2.SelStart := length(edit2.Text);
By the second pressing of a key there is an error: list index out of bounds (1)
How it to avoid?
t := (SRichViewEdit1.RichViewEdit.GetItem(0) as TRVtableItemInfo);
t.Cells[0, 0].GetRVData.SetItemText((sender as tedit).Tag, (sender as tedit).Text);
SRichViewEdit1.RichViewEdit.Format;
t.EditCell(0, 0);
1) I use Cell[0,0].GetRVData instead of Cell[0,0] to access items. Without GetRVData, this code will work correctly only if this cell is not being edited.
2) I added call of Format, it is required after calling a non-editing method like SetItemText.
3) Additionaly, you should call SRichViewEdit1.RichViewEdit.ClearUndo, because calling non-editing method can make data in undo/redo buffers invalid.
Roman2807
Post by Roman2807 »
Has solved a problem so:
  s := (sender as tedit).Text;
  t.EditCell(0, 0);
  t.FInplaceEditor.SetItemText((sender as tedit).Tag, s);
But, SetItemText insert the text without last symbol, and at text removal (by pressing backspace or delete) all is good
Format is required after SetItemText.
Or you can use SetItemTextEd instead of SetItemText. This is an editing method, it updates document itself.
