URL with Ctrl in RichView
monsoon
Post by monsoon »
Sergey Tkachenko wrote:In a read-only editor, hypertext works automatically, without Ctrl. Only when editing, it requires pressing and holding Ctrl.
Whether it is possible to make, that pressing and holding Ctrl work in a RichView?
I do not completely understand your question.
In TRichView and read-only TRichViewEdit, hypertext always work, even without pressing Ctrl.
In editable TRichViewEdit, hypertext works with Ctrl (if rvoCtrlJumps in EditorOptions).
monsoon
Post by monsoon »
Sergey Tkachenko wrote:I do not completely understand your question.
It is necessary for me, that in TRichView hypertext works only with Ctrl and don't work without Ctrl
Sorry, there are no ways to disable hypertext in TRichView.
You can only prevent executing any link if Ctrl is not pressed.
In OnJump event:
procedure TForm1.RichView1Jump(Sender: TObject; id: Integer);
var KeyboardState: TKeyboardState;
  GetKeyboardState(KeyboardState);
  if KeyboardState[VK_CONTROL] and $80 = 0 then
  <process hyperlink click here>
Last edited by Sergey Tkachenko on Wed Jul 28, 2010 1:10 pm, edited 1 time in total.
monsoon
Post by monsoon »
Sorry, I add in event OnJump function GetKeyState for Ctrl and now it's all work
monsoon
Post by monsoon »
Your answer almost same. :wink:
Thanks for help.
