how to print the content of editbox in cells?
maomi1997
Post by maomi1997 »
I insert some editbox in cells,but the print result didn't show the content
of editbox?
how can I do it?
help me,thanks
What's the class name of this edit box?
If RVPrint cannot print some controls, you need to help it by providing a bitmap with a control image, see OnPrintComponent event.
maomi1997
Post by maomi1997 »
I use tcxtextedit
maomi1997
Post by maomi1997 »
I can see the content of the editbox in the screen,but printer's output is blank when I print the richview.
procedure TfrmCheck.btnPrintClick(Sender: TObject);
var printit:Boolean;
 if dlgPrint1.Execute then
   printit:=True;
 if PrintIt then begin
    rvprnt1.AssignSource(rchvw1);
    rvprnt1.FormatPages(rvdoALL);
    if rvprnt1.PagesCount>0 then
      rvprnt1.Print('demo,1,False);
maomi1997
Post by maomi1997 »
screen show
print out pdf format
maomi1997
Post by maomi1997 »
I find I chang tcxedittext to Tedit,the content of contorl can print
When a control is inserted in TRichViewEdit, it works just like if it is inserted in a form.
When printing, TRVPrint needs to create an image of this control. TRVPrint can do it for main standard controls, and tries to draw unknown controls using their PaintTo method. However, this method works not for all controls.
I contacted DevExpress support. I hope we will provide a solution tomorrow.
In the next update of TRichView, TcxTextEdit controls will be printed.
Before that update, you can use TRVPrint.OnPrintComponent event:
uses CtrlImg;
procedure TForm1.RVPrint1PrintComponent(Sender: TCustomRVPrint;
  PrintMe: TControl; var ComponentImage: TBitmap);
  if PrintMe is TcxTextEdit then begin
    ComponentImage := TBitmap.Create;
    ComponentImage.Width := PrintMe.Width;
    ComponentImage.Height := PrintMe.Height;
    TWinControl(PrintMe).PaintTo(ComponentImage.Canvas, 0, 0);
    end
    ComponentImage := DrawControl(PrintMe);
maomi1997
Post by maomi1997 »
thank your repaly.
