I stored RVF file in database table.
Sometimes I need to the export file in RTF format. Is it possible to do without a form with the the RichView control?
Export (save) to RTF without coontrol
You can use TRVReportHelper component. It contains an invisible TRichView itself, but it does not require a form.
If document contains tables, RVReportHelper must be formatted before saving RTF. So you need some canvas for formatting.
helper: TRVReportHelper;
Canvas: TCanvas;
DC: HDC;
helper := TRVReportHelper.Create(nil);
helper.RichView.Style := TRVStyle.Create(helper);
helper.RichView.Options := helper.RichView.Options+[rvoTagsArePChars];
helper.RichView.RVFOptions := helper.RichView.RVFOptions+[rvfoLoadDocProperties];
helper.RichView.RTFOptions := helper.RichView.RTFOptions+[rvrtfSaveDocParameters];
helper.RichView.LoadRVFFromStream(...);
Canvas := TCanvas.Create;
DC := GetDC(0);
Canvas.Handle := DC;
helper.Init(Canvas, 600);
helper.RichView.SaveRTF(...);
Canvas.Handle := 0;
Canvas.Free;
ReleaseDC(0, DC);
helper.Free;
