Convert RTF (in MSSQL blob) in RVF
Tavo
Post by Tavo »
Hello, need some advice
I have a table (MSSQL) that contains a BLOB field (image),
In this field there are documents in RTF format
These documents look good with TDBRichEdit, but If I view with TDBRichView the document is not the same.
1st Question - What is the best way to configure TDBRichViewEdit to view RTF blobs?
I need to convert these documents to RVF format with the least loss.
2nd Question - What is the best way? Is there a link about this topic you can tell me?
Thanks for readme!!!!
What's exactly wrong with these documents loaded in TDBRichView?
Normally, just placing this component on a form and linking to TRVStyle component is enough. Property settings may be required only if you create TDBRichView in code.
