I am using the Rich View Actions Test demo. I want to add Strikeout to the line of buttons. It currently does , Bold, Italic, and Underline.
Here is the procedure that applies them. What do I need to do to add StrikeOut. I already added the button.
procedure TFindingEntry.FontStyleToolButtonClick(Sender: TObject);
var Button: TToolButton;
Button := Sender as TToolButton;
// constants TEXT_BOLD, TEXT_ITALIC and TEXT_UNDERLINE are
// assigned to the tags of corresponding buttons
rve.ApplyStyleConversion(Button.Tag);
Strikeout...
If you really use ActionTest demo, it already has a stikeout button linked to srvActionsResource.rvActionFontStrikeout1 action.
You do not need to write any code to make it work.
But I guess you do not use actions but want to add a new button in Editors\Editor 2\ demo.
1) Add a new constant
TEXT_STRIKEOUT = 9;
(value must be unique among other TEXT_* constants in this demo)
2) Add a button btnStrikeOut : TSpeedButton, assign its properties:
- GroupIndex = 5 (because 1..4 are already used),
- AllowAllUp=True,
- Tag = 9 (equals to TEXT_STRIKEOUT)
- OnClick = FontStyleButtonClick
3) In TForm1.rveStyleConversion, add in "case":
TEXT_STRIKEOUT = 9;
- AllowAllUp=True,
TEXT_STRIKEOUT:
if btnStrikeOut.Down then
FontInfo.Style := FontInfo.Style+[fsStrikeOut]
FontInfo.Style := FontInfo.Style-[fsStrikeOut];
Thanks...
Work great...
