Rich format to pure text, DBSRichViewEdit
agent86
Post by agent86 »
I have 2 MS SQL 2000 datafields,
Finding_Text and
Finding_RichView
I have a dbmemo linked to Finding_Text.
I have a DBSRichViewEdit linked to Finding_RichView
Editing will be done in the DBSRichViewEdit.
When the data is saved in DBSRichViewEdit I want a pure text version saved in Finding_Text.
What to do?
If you use a table component inherited from TDataSet, you can use BeforePost event:
uses RVGetText; (or RVGetTextW if you use Unicode text)
procedure TForm1.Table1BeforePost(DataSet: TDataSet);
Table1.FieldByName('Finding_Text').AsString := GetAllText(DBSRichViewEdit1.RichViewEdit);
agent86
Thank you! and a question...
Post by agent86 »
Thank you for the quick reply.
Do you know if there are any samples the use the DBSRichViewEdit? I couldn't find any.
Does it essentially work the same way as the SRichViewEdit so that the examples work for both DBSRichViewEdit and SRichViewEdit?
Yes, DBSRichViewEdit works like SRichViewEdit.
You can use RichViewActions for it as well. But do not use New-Open-Save-SaveAs actions, they are related to files.
agent86
Keep Strikeout?
Post by agent86 »
Is there anyway to keep strikeout?
Keep where?
agent86
Do not lose sriekout when going to pure text
Post by agent86 »
Is ther a way to GetAllText and leave strikeout in place. When I tested it the strikeout disappears as well.
But strikeout (if you mean fsStrikeOut in Style) cannot be stored as text.
You need to get data in RTF or RVF format instead.
