Getting text as rtf
nickg
Getting text as rtf
Post by nickg »
If I want to use TRichView in Unicode mode, is there a way to get the text and it's rtf formatting codes so I can load the whole thing into a widestring, or an OLEVariant.
No objects or paragraph formatting is required, just font name, style, color, and size. And the text of course :-)
TIA Nick
You can use SaveRTFToStream method to save RTF in TStringStream, then get a string from Stream.DataString
nickg
Getting rtf text from TRichView
Post by nickg »
Many thanks Sergey, I'll try that.
Regards Nick
