Replacement for DBMemo.Font.Color / Visual disable Control?
Bjoern
Post by Bjoern »
I'm using a DBRichViewEdit (as a replacement of a DBMemo) and some DBEdits on a DBCtrlGrid.
In some cases i must show the user that a data-record is disabled, so far i used the OnPaintPanel-Event of the DBCtrlGrid with
if (MyDBCtrlGrid.DataSource.DataSet.FieldByName('disabled').AsBoolean) then
   MyDBEdit.Enabled:= False;
   MyDBMemo.Enabled:= False;
   MyDBMemo.Font.Color := clGray;
end
   MyDBEdit.Enabled:= True;
   MyDBMemo.Enabled:= True;
   MyDBMemo.Font.Color := clBlack;
so both Controls, the DBEdit and the DBMemo shows the user that editing is disabled.
At the DBRichViewEdit there is no .Font and when i loop through the TextStyles and set all Fontcolors for all styles to gray, then the original-color is lost when the data-record is enabled again.
Is there any alternative to make all fonts gray, only viewable at the control, no change in the database?
Sorry, no. May be you can assign DBRichViewEdit.Color := clBtnFace instead?
Last edited by Sergey Tkachenko on Wed May 12, 2010 1:08 pm, edited 1 time in total.
Bjoern
Post by Bjoern »
I'll try this and to make the DBEdit.Color darker too when disabled.
Maybe something for the next version of TRichViewEdit, a property like .DisabledFontColor?
Will be in the next update
