Table Center and View like Word
Artis
Post by Artis »
I am discovering Richview and it's really impressive.
I have read the help file, but i have two questions.
1) In a RichViewEdit, if i do :
  Table := TRVTableItemInfo.CreateEx(1,3,RVe_CR.RVData);
  Table.BestWidth := -80;
  Table.CellHPadding := 3;
  Table.ParaNo := 1;  //This ParaStyle is Centered
  Table.InsertRows(Table.RowCount,1,0);
  RVE_CR.InsertItem('CompteResultat', table);
  RVE_CR.Format;
The table is not centered??
2) I reuse the code of ActionTest demo.
is it possible to view only A4 page and not a blank page larger than 21 cm?
Like MsWord or OpenOffice in Standard mode.
Thanks,
Artis
1) If you want to insert the table in the caret position, as editing operation (undoable):
  RVE_CR.ApplyParaStyle(1); //This ParaStyle is Centered
  // format is not needed after editing method
InsertItem ignores ParaNo specified in the item, it uses ParaNo of the paragraph at the point of insertion.
If you want to add table to the end of document, not as editing operation:
  RVE_CR.AddItem('CompteResultat', table);
  RVE_CR.Format;
2) I am not sure that I understand the question. If you want to display pages, you can use ScaleRichView addon.
