rvtoNoCellsSplit option
mediasofts
Post by mediasofts »
I use an old version of TRichViewEdit ( 1.9.48 ).
in RVTable Unit there is TRVTablePrintOption type :
TRVTablePrintOption = (rvtoHalftoneBorders, rvtoRowsSplit, { rvtoNoCellsSplit, }  rvtoWhiteBackground);
who got "rvtoNoCellsSplit" comented.
i found "rvtoNoCellsSplit" on the same file, line 1326 :
function TRVTablePrintInfo.CanSplitFirst(Y: Integer;
  const Sad: TRVScreenAndDevice; FirstOnPage,
  PageHasFootnotes, FootnotesChangeHeight: Boolean): Boolean;
var BorderHeight, StartHeight, ExtraCellHeight,
    DeltaBottomHeight, RemainingHeight, c, mr, mc, ColCount,
    HeightAfterFootnotes: Integer;
  if PartsList.Count=0 then begin
    Result := False;
  if [b]rvtoNoCellsSplit in FTable.PrintOptions [/b]then begin
    BorderHeight := Fmt.FHeight-Fmt.RowStarts[Fmt.RowStarts.Count-1]-
      Fmt.RowHeights[Fmt.RowStarts.Count-1];
    dec(y, BorderHeight);
    mr := FTable.GetSplitRowBelow(FHeadingRowCount);
    Result := y>Fmt.RowStarts[mr]+Fmt.RowHeights[mr];
  BorderHeight := RV_YToDevice (FTable.BorderWidth+FTable.BorderVSpacing, Sad);
My question is :
How can i activate simply the "rvtoNoCellsSplit" option ?
Thanks,
David
Sorry, this feature is not implemented. It appeared to be more complicated than expected.
To keep the content of cells together, you can use rvpaoKeepWithNext and rvpaoKeepLinesTogether options for paragraphs.
