What program is opening RichView Help ?
What is the name of the file/program which opens RichView.hlp ?
Can a link to RichView Help be easily added to the Delphi 2010 IDE ?
Currently, TRichView help is available in
- (obsolete) WinHelp format: http://www.trichview.com/rvfiles/rvhelpfile.zip , can be integrated in Delphi 4-7,
- HTML help: http://www.trichview.com/rvfiles/rvchm.zip , can be opened in standard Windows help,
- PDF: http://www.trichview.com/rvfiles/rv_pdf_manual.zip , can be opened in Adobe Reader
- RTF: http://www.trichview.com/rvfiles/rv_rtf_manual.zip , can be opened in MS Word or any other RTF editor, including TRichView itself;
- online help: http://www.trichview.com/help/
Sorry, integration in D2010 help system is not possible yet.
Last edited by Sergey Tkachenko on Wed Mar 31, 2010 5:37 pm, edited 1 time in total.
A temporary work-a-round solution for D 2010
Open Tools menu
GOTO
Configure Tools
click "Add" in Tool Options window
in the Tools Properties window type
Name : RichView HTML Help
Program: C:\Program Files\Mozilla Firefox\Firefox.exe (or whatever HTML web-browser you prefer)
Working Dir: (leave Blank)
Parameters: http://www.trichview.com/help/
and voir-la you have help in the Delphi IDE
GOTO
Configure Tools
Here is how to do it for RichView.chm
or try this.
download help file (RichView.chm) and place it in folder outside 'Program Files' eg C:\Help
I have been unable to get it to work from Delphi 2010 IDE using Program Files in the file path.
Open Tools menu
GOTO
Configure Tools
Name : RichView CHM Help
Program: C:\Windows\HH.exe
Parameters: C:\Help\RichView.chm
Open Tools menu
GOTO
Configure Tools
Actually that file does not work....
I found I had to use
1-TRichView\Help\RichView.chm from rvHelp.zip
I found that the file at
does not work for some reason.
This is what actually works...
http://www.trichview.com/rvfiles/rvhelp.zip
use RichView.chm in
Open Tools menu
GOTO
Configure Tools
use RichView.chm in
Open Tools menu
GOTO
Configure Tools
Still can't get that file to work...
I tried redownloading that file
It never works for me ...
Can someone else please download this file, extract it, and left double-click it and see if the following error message appears...
" Web page unavailable offline
Internet Explorer is unable to display this page when you are not connected to the Internet.
Please try the following:
To make this page available offline, connect to the Internet, click the Favorites menu, click Add to Favorites, and then select the Make available offline check box.
On the Tools menu, click Synchronize.
When you work offline, select the page from your Favorites list.
Internet Explorer "
Internet Explorer "
File size is as you say but it never opens..
Something is definitely strange about that file...at least on my computer.
Anyway the other file in rvhelp.zip works fine for me.
If anyone else has a problem with this file (rvchm.zip) please let us know..
