Greetings Sergey and all,
paragrpahs with numbering result in RTF in
number<tab>text
The tab is, at least, choosen by MS Word as a separator. Is there a way to change that? For centered headings, a tab character is most likely not what you want, instread, a single space would be good.
Moritz
(TRichView 12.1)
RTF and paragraph numbers
Because in centered paragraphs, it may be desirable to get equal spacing between any paragraph number and the text, regardless of the width of the number.Sergey Tkachenko wrote:Why not tab?
1 Terms of use
21 Liability
104 Termination
1 Terms of use
21 Liability
104 Termination
It can be implemented simpler: by aligning list marker to the right.
In RichViewActions, in the numbering customization dialog, select in "Number position": <align right> at <N>, where <N> - distance from the left margin to the right side of the number (assuming that the paragraph is left-aligned).
In code, these properties are:
- MarkerAlignment: http://www.trichview.com/help/idh_trvli ... nment.html
- MarkerIndent: http://www.trichview.com/help/idh_trvli ... ndent.html
