[Unit] Adding a table of contents
Overview of "table of context" solutions for TRichView and ScaleRichView:
http://www.trichview.com/forums/viewtop ... 702#p34702
Unit RVTOC.pas:
rvtoc.zip
(3.47 KiB) Downloaded 11049 times
It has the functions:
function AddTableOfContents(rv: TCustomRichView; RVPrint: TRVPrint;
  Depth: Integer; const TextStyleNos, ParaStyleNos: array of Integer;
  ItemNo: Integer; const Title: TRVUnicodeString; TitleStyleNo, TitleParaNo: Integer): Boolean; overload;
function AddTableOfContents(RVReportHelper: TRVReportHelper; Canvas: TCanvas;
  PageWidth, FirstPageHeight, PageHeight: Integer;
These procedures add a table of contents (TOC) to RichView.
Version for TRVPrint
TOC is added in rv.
TOC is inserted in the position specified in ItemNo.
Possible values of ItemNo:
* 0 - inserting at the beginning of rv;
* rv.ItemCount - inserting at the end of rv
* any value from 1 to rv.ItemCount-1 - inserting before the item with this index; this item must have a page break (i.e. rv.PageBreaksBeforeItems[ItemNo] must be True), otherwise this function does nothing and returns False.
This function returns True on successful inserting. If the document does not have headings with levels in range 1..Depth, this function does nothing, but still returns True.
RVPrint must be formatted before the call of this function. After the call, it is not formatted (call RVPrint.FormatPages again before printing).
Rv is not formatted after the call of this function (call rv.Format before displaying it).
Title is added before the TOC, using TitleStyleNo and TitleParaNo styles. Depth is a maximal heading level for TOC.
TextStyleNos and ParaStyleNos are arrays containing styles for TOC. They must have Depth items.
TitleStyleNo[0] and TitleParaNo[0] are used for adding heading level 1 in TOC,
TitleStyleNo[1] and TitleParaNo[2] are used for adding heading level 2 in TOC,
and so on.
TOC is added not as an editing operation! Undo is not possible. If called for TRichViewEdit, call ClearUndo method.
// TitleStyleNo, TextStyleNos[] are indices in rv.Style.TextStyles collection.
// TitleParaNo, ParaStyleNos[] are indices in rv.Style.ParaStyles collection.
TOC is added as Unicode strings in Delphi 2009-2010, and as ANSI strings in older version of Delphi (so foreign characters may be lost on conversion)
Version for TRVReportHelper
In this version of the function, the document is contained in RVReportHelper.RichView.
Additional parameters:
Canvas - a canvas that was used for RVReportHelper.Init(), or another canvas with the same resolution;
PageWidth - width of pages (used in Init).
FirstPageHeight - height of the first page (used in FormatNextPage)
PageHeight - height of other pages (used in FormatNextPage)
These parameters are used only if ItemNo<RVReportHelper.RichView.ItemCount (i.e. if TOC is added not to the end). If the TOC is added to the end, you can pass any values to these parameters.
RVReportHelper must be formatted before the call of this function.
After the call, it is not formatted.
Additional procedure
procedure GetStylesForOutlineLevel(rv: TCustomRichView; Level: Integer;
  var StyleNo, ParaNo: Integer);
This procedure searches for the first occurence of the paragraph with OutlineLevel=Level, and returns:
- the style of this paragraph (in ParaNo),
- the style of text in this paragraph (in StyleNo).
Paragraphs without text are ignored. If there is no such paragraph, this procedure returns 0, 0.
These values can be used as TitleStyleNo, TitleParaNo parameters for AddTableOfContents.
[+] Updates
2018-Apr-18: for compatibility with TRichView 17.3; fixed the margin problem in the RVReportHelper version
[+] Old versions
http://www.trichview.com/support/files/rvtoc.zip - for TRichView: 12.2.3 - 17.2
Last edited by Sergey Tkachenko on Sun Apr 25, 2010 7:57 pm, edited 8 times in total.
How to use
Example for TRVPrint
procedure GetPageSize(RVPrint: TRVPrint;
  var Width, Height: Integer);
var DC: HDC;
    phoX, phoY, phW, phH, lpy, lpx, LM, TM, RM, BM: Integer;
  DC := RV_GetPrinterDC; // from PtblRV unit
  Width  := GetDeviceCaps(DC, HORZRES);
  Height := GetDeviceCaps(DC, VERTRES);
  lpy := GetDeviceCaps(DC, LOGPIXELSY);
  lpx := GetDeviceCaps(DC, LOGPIXELSX);
  phoX := GetDeviceCaps(DC, PHYSICALOFFSETX);
  phoY := GetDeviceCaps(DC, PHYSICALOFFSETY);
  phW  := GetDeviceCaps(DC, PHYSICALWIDTH);
  phH  := GetDeviceCaps(DC, PHYSICALHEIGHT);
  // RV_UnitsToPixels is defined in RVFuncs unit
  LM := RV_UnitsToPixels(RVPrint.Margins.Left,  RVPrint.Units,  lpx) - phoX;
  TM := RV_UnitsToPixels(RVPrint.Margins.Top,   RVPrint.Units,  lpy) - phoY;
  RM := RV_UnitsToPixels(RVPrint.Margins.Right, RVPrint.Units,  lpx) - (phW-(phoX+Width));
  BM := RV_UnitsToPixels(RVPrint.Margins.Bottom, RVPrint.Units, lpy)- (phH-(phoY+Height));
  if LM<0 then LM := 0;
  if TM<0 then TM := 0;
  if RM<0 then RM := 0;
  if BM<0 then BM := 0;
  dec(Width, LM+RM);
  dec(Height, TM+BM);
  DeleteDC(DC);
  DC := GetDC(0);
  Width  := MulDiv(Width,  GetDeviceCaps(DC, LOGPIXELSX), lpx);
  Height := MulDiv(Height, GetDeviceCaps(DC, LOGPIXELSY), lpy);
  ReleaseDC(0, DC);
// Returning Width and Height or printable area (inside margins) of RVPrint.
// The returned values are measured in screen pixels
// Adds Count paragraph styles in rv.Style (or reusing existing styles, if possible).
// Indices of these styles are returned in ParaStyleNos
// (this array must have at least Count items).
// All these paragraphs have one right-aligned tab stop at the position
// equal to the width of printable area in RVPrint.
// Each next paragraph is indented by IndentStep.
procedure GenerateTOCParagraphs(rv: TCustomRichView; RVPrint: TRVPrint;
  Count, IndentStep: Integer; var ParaStyleNos: array of Integer);
var ParaStyle: TParaInfo;
    Width, Height, i: Integer;
  GetPageSize(RVPrint, Width, Height);
  dec(Width, rv.LeftMargin+rv.RightMargin);
  ParaStyle := TParaInfo.Create(nil);
    with ParaStyle.Tabs.Add do
      Position := Width-1;
      Align := rvtaRight;
      Leader := '.';
    for i := 0 to Count-1 do
      ParaStyle.LeftIndent := IndentStep*i;
      ParaStyleNos[i] := rv.Style.FindParaStyle(ParaStyle);
    ParaStyle.Free;
// Adding 3-level TOC
var ParaStylesNo: array [0..2] of Integer;
    TitleStyleNo, TitleParaNo: Integer;
  RVPrint1.AssignSource(RichViewEdit1);
  RVPrint1.FormatPages(rvdoAll);
  GetStylesForOutlineLevel(RichViewEdit1, 1, TitleStyleNo, TitleParaNo);
  GenerateTOCParagraphs(RichViewEdit1, RVPrint1, 3, 24, ParaStylesNo);
  AddTableOfContents(RichViewEdit1, RVPrint1, 3, [0,0,0], ParaStylesNo, RichViewEdit1.ItemCount,
    'Table of Contents', TitleStyleNo, TitleParaNo);
  RichViewEdit1.Format;
Example for TRVReportHelper
// Adds Count paragraph styles in RVReportHelper.RichView.Style
// (or reuses existing styles, if possible).
// equal to the Width.
procedure GenerateTOCParagraphs(RVReportHelper: TRVReportHelper; Width: Integer;
    i: Integer;
  dec(Width, RVReportHelper.RichView.LeftMargin+RVReportHelper.RichView.RightMargin);
      Align := rvtaRight;
      Leader := '.';
      ParaStyleNos[i] :=
        RVReportHelper.RichView.Style.FindParaStyle(ParaStyle);
    ParaStyle.Free;
// Variables:
// rvh: TRVReportHelper
// Canvas - canvas used for rvh.Init
// PageWidth, PageHeight - page size
    rvh.Init(Canvas, PageWidth);
    while rvh.FormatNextPage(PageHeight) do;
    GetStylesForOutlineLevel(rvh.RichView, 1, TitleStyleNo, TitleParaNo);
    GenerateTOCParagraphs(rvh, PageWidth, 3, 24, ParaStylesNo);
    AddTableOfContents(rvh, Canvas, PageWidth, PageHeight, PageHeight,
      3, [0,0,0], ParaStylesNo, rvh.RichView.ItemCount,
Update:
2018-Apr-18:
the code samples use new features of TRichView 17; they were made simpler; they do not use obsolete properties any more
Last edited by Sergey Tkachenko on Sun Apr 25, 2010 3:06 pm, edited 3 times in total.
Possible ways to improve:
1) Inserting as an editing operation (that can be undone by the user).
2) The same function for RVReportHelper instead of RVPrint.
3) The same function for ScaleRichView.
4) Working via Unicode even for old versions of Delphi (4-2007)
On request.
Update:
2, 3, and 4 have been implemented
jonjon
Post by jonjon »
Great stuff Sergey.
A couple of questions though. Does it work if the table of content will not fit on one page ? Also, sometimes there are cover pages or titles pages before the table of content: how could it be inserted just after those pages ?
Finally, the RVReportHelper would be nice.
Best regards.
Yes, multipage TOC is handled correctly.
As for title pages... How do you think it will be convenient to define them? Specifying ItemNo where to insert TOC?
Or do you want to insert it in editor, in the caret position?
jonjon
Post by jonjon »
I think specifying ItemNo might be the best option to place it correctly.
Updated. The parameter ToBeginning is superseded by the parameter ItemNo. Limitation: when inserting to the middle, there must be a hard page break at this ItemNo.
As for TRVReportHelper, it appears to be more difficult. The function needs to know not only Width specified in Init, but also heights of all pages specified in FormatNextPage, and heights of new pages (since adding TOC increases the count of pages).
allanj42
Post by allanj42 »
Thank you, Sergey, for the GetPageNo() method and for the example.
I seem to have it working in my app, but I would like to better understand GetPageNo(). Where can I get documentation for RV 12.2.3 and/or this method? In particular, why is the first parameter necessary when I have already assigned an RVData to the RVPrint?
In GetPageNo, RVData parameter may be:
- rv.RVData, where rv is a TRichView control assigned in RVPrint.AssignSource
- table cell.
You can see how GetPageNo used in RVTOC.pas, in function BuildTOCStructure.
jonjon
Post by jonjon »
Any news on the RVReportHelper version ? Or is it impossible ?
Regards,
John.
I have updated the unit, a function for TRVReportHelper is included.
The messages above are updated as well, with information and example for TRVReportHelper.
This version has a limitation - only two values of a page height are possible: one for the first page, one for other pages. I believe it covers 99.9% of cases, since different heights for all pages are rarely needed.
Last edited by Sergey Tkachenko on Tue Sep 21, 2010 12:31 pm, edited 1 time in total.
This feature is implemented for ScaleRichView, see DocViewer demo:
http://www.trichview.com/forums/viewtopic.php?t=3890
jonjon
Post by jonjon »
Sergey,
How hard would it be to update the code to also produce a table of contents for a standard TRichView(Edit) which, instead of adding fixed page numbers, would export it using the "PAGEREF" RTF code such as Microsoft Word ?
If you already have a demo on how to achieve that, it would be very useful.
Thanks in advance,
John.
jonjon
Post by jonjon »
Sergey, any comment about my previous message ?
I need to study how MS Word creates TOC. I'll answer later in this week, sorry for delay.
