Get all Imagenames
grolle
Get all Imagenames
Post by grolle »
I save tRichView content as html. Works perfect, but I have one question: tRichView changes the names (1.jpg, 2.jpg ...). How did I get these names? Are they stored somewhere in an array or something? Reason: I must know the names because I have to change some Image tags in the html document, after saving it.
Best regards ...
These file names are autogenerated and not stored.
You can use OnSaveImage2 event:
procedure TForm3.RichViewEdit1SaveImage2(Sender: TCustomRichView;
  Graphic: TGraphic; SaveFormat: TRVSaveFormat; const Path,
  ImagePrefix: String; var ImageSaveNo: Integer; var Location: String;
  var DoDefault: Boolean);
  if SaveFormat = rvsfHTML then begin
    Location := Sender.SavePicture(SaveFormat, Path, Graphic);
    // now Location contains file name that will be saved in HTML
    DoDefault := False;
grolle
Post by grolle »
That's it. Thanks :)
