insert picture memory usage problem
cychia
Post by cychia »
I have done a test using RichViewAction demo, insert a picture around 2 mb from local file. and check the memory usage in Task Manager it shoot higher than 2 mb. then i delete the picture, the memory usage does not reduce, any idea?
Picture is loaded in the corresponding TGraphic class, like TBitmap or TJpegImage. The amount of used memory depends on them.
When you delete the picture in the editor, it is not freed but moved in the undo buffer.
cychia
Post by cychia »
ic, thanks
